Problem with 5540 Unit
Archived from groups: alt.video.ptv.replaytv (More info?)
Hi,
I have a 5540 that is about 2 years old. Recently I have been
experiencing the the following:
1. Live mode: Picture is frozen and audio keeps repeating
about 5 secs in endless loop. It started doing it
when changing channels but recently it seems to get
stuck even after a reboot.
2. Replay mode locally: Playing already recorded shows is OK.
It does take a while to get the menu due to (1).
3. Replay mode to a 5040: Works fine
4. Replay mode from a 5040: works fine
5. Other Issues: Occassional severe pixelation on local channels.
I was thinking that this is an issue with the satellite
but does not happen on the 5040 (but could be due to the
different DirecTV receiver).
Has anyone seen this? Is this a hard drive issue (I wanted to
rule that out since recorded shows play fine).
Any info appreciated.
Thanks
Felix
2 answers Last reply
More about problem 5540 unit
  1. Archived from groups: alt.video.ptv.replaytv (More info?)
    On Sun, 20 Mar 2005 09:46:25 -0800, F. Chung <f@nospam.com> wrote:
    >Hi,
    It may still be one. Note that when buffering live TV (rather than
    playing a recorded show), the Replay is doing BOTH recording and
    playing at the same time (with a controllable delay that's at least 1
    sec or so). The disk may be fast enough for either one, but not both
    at the same time (the playback is effected first). Try it with a new
    drive (or just a new software image, it that doesn't fix it use a new
    drive)..
    >Thanks
    >Felix
    Mark Lloyd
    has a Replay 5xxx
    http://notstupid.laughingsquid.com
    "The idea that there is an invisible being who
    created and still runs this old universe is so
    childish, so obviously contrived, that it is hard to
    believe anyone with even a modicum of education can
    still fall for that scam."
  2. Archived from groups: alt.video.ptv.replaytv (More info?)
    F. Chung wrote:
    > Hi,
    Since everything is digital this could be due to any of the following
    Bad LNA (Dish head unit) Bad cable, staple through cable (or nail) bad
    cable box, bad drive in the Replay, bad other in the replay. and most
    likely a bad connection somewhere on the signal path TO the replay
    (Check all connections for corrosion and pulled wire)
    Different signal paths, different LNA (Lo, Noise Amplifier) at the dish,
    Different cable, Different cable, box,,, Different EVERYTHING
    Do you watch local channels locally or via the sat? (Your own antenna or
    what)
    One thing I have noticed about the replay is that it will pixelate if
    it's not getting a strong enough signal when watching "Off the air"
    (Connected to an antenna) I ran mine for a while on a set of rabbit ears
    To test the replay you need an alternative video source, A dvd player
    would be nice... Hook it up to LINE 2 and see how it records... I it
    records fine and plays through fine, then you have elimanted almost all
    of the replay as the culprit (How much is left to elimante depends on
    how you are hooked to the cable box.
    To test the cable box,,, Hook up a tv or video monitor in place of the
    replay....
    This is an elimination test... A very definitive test as far as it goes
    If the picture off the cable box is defective, stutters, pixelates, and
    such..... Suspect it and it's upstream devices (Call your cable/sat
    provider) if the pic suffers when viewing/recording from a DVD player...
    Suspect the Replay
Ptv Replaytv
