Not going to get much if any. your better luck would be to check on Ebay and see what similar parts are going for. The BIGGEST problem is, laptops are NOT 'part swappable', so for example I may have a ATI card in my laptop and I want the 630m instead, well my laptop may not be able to even support that card, much less actually FIT IT inside. So I would look at seeing if anyone with Lenovo laptops wants the internal parts only. Maybe $100 ? Since it is 'used' and there is risk on the buyer it may die in a couple months, rather then (like you are) just 'save and buy' a new one under warranty.
