A handheld-PC, portable-PC, pocket-PC, PDA, or otherwise small 9"-10"-ish wide laptop that uses AAs, has as long a battery lif
  • Laptops
  • Portable Device
  • Mobile Computing
Last response: in Mobile Computing
August 17, 2014 3:13:03 PM
A handheld-PC, portable-PC, pocket-PC, PDA, or otherwise small 9"-10"-ish wide laptop that uses AAs, has as long a battery life as possible and is lightweight, qwerty keyboard, and quiet.
Some options I'm looking at right now:
Casio Cassiopeia A-21S Handheld PC
NEC Mobilepro 780 Portable Computer
Tandy TRS-80 Model 100
More about : handheld portable pocket pda small ish wide laptop aas long battery lif
a c 232 D Laptop
September 19, 2014 12:26:37 PM
Exactly why AA batteries? You are limiting yourself to larger heavy old devices with less battery life than modern ones.
