So this is a very specific problem and posting this is my absolute last resort.
I built a new computer for my friend.
Asus Z87-Pro MB,
16GB G.Skill RAM,
Gigabyte GTX 760 4GB,
i5 Intel QC 3.5 gHz CPU and
750 watt Ultra PSU.
It worked like a CHARM the first time i turned it on. Went right to the windows install and was about half way done. It turned off and reset which i thought was a part of the install. Turns out the CPU had overheated because I put too much thermal paste. Cleared it out, tried again. The computer started turning on and off repeatedly by itself.Cleared the paste AGAIN, which brings us to the problem I have now: Computer turns on, and stays on. No video on monitor, DRAM LED light is solid red. I have nooooo clue whats going on here. The thing that gets me the most is that it worked once. Ive literally never seen or heard of this happening to a computer.
Asus Z87-Pro MB,
16GB G.Skill RAM,
750 watt Ultra PSU.
