Power Supply for my build
  • Gaming
  • Power Supplies
  • Components
  • Build
  • New Build
Last response: in Components
August 21, 2014 11:24:26 PM
Hi guys,
Below is the build for the system I am planning to assemble.My only question is whether the 750W PSU is ideal for this build, I don't plan on upgrade/add anything for the next few years.
Any advice on the build is highly welcome.
thanks in advance
INTEL I-7 4790
ATI R9 270 2GB 5 B,OC HIS
8GB DDR3 CORSAIR VENGENC
Gigabyte GA-Z97M-D3H
Seasonic M12II-750 Bronze(Modular)
Seagate 1TB SSHD SATA (ST1000DX001)
cooler Master N300 KKN1(Mid Tower)
More about : power supply build
August 21, 2014 11:42:54 PM
That psu is more than enough. You could get away with a seasonic m12II 520 watt model.
August 22, 2014 12:40:23 AM
@Rybo I just want a silent PSU with which produces as little heat as possible. are you sure that 520W wont pose any problems, cause I wont mind a 520 as its a lot cheaper than 750( like 30$ cheaper for me).
a b ) Power supply
August 22, 2014 1:00:56 AM
For your build 520 is enough (Seasonic S12II 520). But you need to buy a haswell compatible PSU.
I see in Seasonic site the lowest that Seasonic claims is haswell compatible is M12II650 bronze.
http://www.seasonic.com/new/twevent20130510.htm
Alternatively you can buy a XFX 550 W. Great PSU and compatible.
August 22, 2014 1:47:59 AM
Thanks , I never knew about the compatibility. if I use higher watt psu will it have any effect on my system in terms of heat or noise ??
I am unable to get xfx in india and import costs will be huge but I can get a seasonic M12II 650 for around 115$ or a corsair CX600 for 77$
a b ) Power supply
August 22, 2014 2:01:10 AM
I am from India too :)  I If you can afford the Seasonic, get it. I myself use a couple of them and they are great.
Usually they are very quite PSU's.
a b 4 Gaming
a b ) Power supply
August 22, 2014 5:19:21 AM
Are you just going to use this for gaming? The 4690 or 4590 should do fine in that case and would save money.
You also can get away with a H97/H87/B85 motherboard for the last two with the right bios.
Saved money could go to a better gpu for instance.
a b 4 Gaming
a b ) Power supply
August 22, 2014 5:35:56 AM
Totally agree, less cpu and more gpu if you're gaming.
August 22, 2014 6:00:23 AM
Thanks guys for the help. I changed my configuration as per @Vic's suggestion to this and thanks bluemoon I will be keeping the seasonic 750(in india there isn't much difference in price between the 650 & 750). I will be creating a new topic for a decent looking but small computer case.
INTEL I-5 (4590)
GIGABYTE H97-D3H
it just brought my expenses down by a hundred dollars or so. I will search around for a better graphic card with reasonable price.
a b 4 Gaming
a b ) Power supply
August 22, 2014 6:20:13 AM
Looks good so far.Be carefull that a "small but decent case" supports that atx motherboard.
August 22, 2014 10:49:51 AM
INTEL I-5 (4590)
GIGABYTE H97-D3H
You could bump up to an R9 280 or a gtx 760.
