Is this audio system compatible
  • Audio
  • Toyota
  • Compatibility
Last response: in Cars
September 2, 2014 3:52:58 AM
Was wondering if any audio guru's can help me out, bought my first car recently (1994 Toyota Camry) and was wondering if the audio system I picked out would be compatable. If they aren't could someone show me a system that would work, but is cheap (For Australia)
http://www.supercheapauto.com.au/online-store/products/...
Thank you to anyone that helps :)
More about : audio system compatible
September 2, 2014 4:03:50 AM
Yes - they'll all work - as long as you can fit it.
Have a look in JB Hifi too.
m
l
September 2, 2014 4:29:58 AM
I'm very certain they'll fit, just wanted to know if only certain speakers and units were compatible, very new to this topic, but thank you for the help.
m
l
September 2, 2014 5:03:02 PM
Everything will fit just fine. You won't have any issues with the depth of anything. It should all be pretty much able to bolt in. This is the website I use for car stereo information. It might help you as well:
http://www.modifiedlife.com/1994-toyota-camry-car-audio...
m
l
