Water cooling mountering
  • Water Cooling
  • Cooler Master
September 23, 2014 3:02:34 AM
Hi guys im contemplating getting the COOLER MASTER Seidon 120V Watercooling kit however my case is the Cooler master K380 which does not have a top 240 mount but it does have 120 mount on the bottom in front of the PSU but I'm worried putting it there my affect cooling as the coolant will have to travel up hill to get to the CPU, is this a concern? and I would prefer to keep my rear exhaust fan where it is but if you think the cooling unit is better suited there then OK.
Thanks
More about : water cooling mountering
September 23, 2014 3:08:50 AM
I would use the 120mm exhaust and have it exhausting out of the case.
September 23, 2014 3:18:51 PM
Would the 120 fan that i have on the exhaust at the moment be good on the bottom of the case?
September 24, 2014 1:52:43 AM
Yeah you could use it as an intake there, or you could use both on the radiator in push/pull.
