R9 280x with 3 fans will fit with the p55a-ud3 motherboard or their will be barriers in the way of fans ??
  • Components
  • AMD
  • Gigabyte
  • Motherboards
  • Cases
  • Graphics Cards
September 25, 2014 7:27:05 AM
if i will buy the GV-R928XOC-3GD i know it will fit in the PCIE x16 2.0 slot but i am asking does the length of the card with the 3 fans will fit in the motherboard Gigabyte Ga-P55a-UD3 or their will be any barriers in the way of the fans ?? like the marked component in the picture
https://www.mediafire.com/?cuirsz1hh9a51ym
More about : 280x fans fit p55a ud3 motherboard barriers fans
a b À AMD
a b V Motherboard
a c 79 U Graphics card
September 25, 2014 7:38:05 AM
The card will fit into the motherboard. Manufacturers carefully measure the height of their motherboard heatsinks to make sure they don't interfere with any add-on cards. Also I would find it hilarious if a Gigabyte board got into the way of a Gigabyte card.
a b À AMD
a b V Motherboard
September 25, 2014 8:39:05 AM
Can you just tell me the model name of the case? That site is set up oddly as it does not have dedicated links for their products.
September 25, 2014 8:42:55 AM
gamma HEC 6C29
but it is in egypt i think not global manfacturer or something
anyway its dimensions are :190 X 410 X 450 mm
September 25, 2014 8:42:58 AM
gamma HEC 6C29
a b À AMD
a b V Motherboard
September 25, 2014 8:50:00 AM
You might have to get a bigger case as that case is only 450mm long and the R9 280X is 385mm long. Now while it's still shorter than the case it probably won't fit due to the hard drive bays being in the way of the card. Or you could choose a shorter card. The Sapphire R9 285 ITX edition card isn't that much weaker than the 280X but will definitely fit in your case.
September 25, 2014 9:42:08 AM
are you sure it is 385 mm long ? because in gigabyte website it is just 285 mm long
http://www.gigabyte.com/products/product-page.aspx?pid=...
