Can someone please select the parts on pcpartpicker for me which can play bf4,titanfall etc on ultra settings
  • Components
Last response: in Components
September 27, 2014 2:00:09 AM
Need help, wanna have rig which can play bf4,titanfall on ultra for minimum price as possible
More about : select parts pcpartpicker play bf4 titanfall ultra settings
September 27, 2014 2:43:32 AM
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($179.99 @ NCIX US)
Motherboard: Gigabyte GA-H97-GAMING 3 ATX LGA1150 Motherboard ($77.99 @ Amazon)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory ($92.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($56.98 @ OutletPC)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card ($199.99 @ Newegg)
Case: Corsair SPEC-03 White ATX Mid Tower Case ($45.00 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($44.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ OutletPC)
Total: $717.91
Generated by PCPartPicker 2014-09-27 05:43 EDT-0400
September 27, 2014 11:56:16 AM
Thanks
September 27, 2014 1:22:45 PM
welcome.
September 28, 2014 4:01:45 AM
Is 1600 quick enough ram?
September 28, 2014 5:00:45 AM
watchdogs is a over demanding game with worst coding ever and r9 280 3gb is much better than gtx 760.
and yes 1600 mhz is enough you can get 2400 mhz of ram but in gaming you will barely see any difference.
September 28, 2014 5:08:38 AM
Nonsense, the 760 and 280 are neck and neck in most games, sometimes the 280 slightly outperforms the 760 and sometimes the 760 slightly outperforms the 280.
As for watchdogs being a bad port yes it is and it absolutely hammers systems with less than 3gb of vRAM. Unfortunately this seems to be a growing trend due to the new consoles having a lot of vRAM available and I think this trend will continue sadly. All I'm saying is that in the future 4gb of vRAM is probably going to be seen as a minimum amount in many new games.
Edit Though you are right the 280 is better than the 760 in bf4! Sorry! Just trying to think about the future!
September 28, 2014 5:20:32 AM
If you spend 240 $ for gtx 760 then its better to spend 30$ more for gtx 770.
September 28, 2014 5:26:58 AM
But I bet it's more than $30 extra for the 4gb version :(
Really, why didn't they just put 4gb in the r9 280 grrrr!?
I just keep coming back to the "etc" in the OP. They've stipulated "ultra" settings and if they want ultra in newer games that have been badly ported like Watchdogs and The Evil Within then they will need all the vRAM they can get
September 28, 2014 10:00:55 AM
yes thats why i have told that watchdogs is one of the most badly coded game but i have gtx 760 2gb version and i have played it on ultra settings with some graphic adjustments and i have got 40 - 50 fps.
