Which type of case fan do you suggest? (Case: Lian-Li PC-D600; GPU: Sapphire HD7990)
  • airflow
  • static pessure
  • Fan
  • Components
  • Cases
  • Lian Li
Which setup type?
See results
September 30, 2014 4:17:26 AM
Hey :)
I want to buy a new case and I chose the Lian-Li PC-D600 which is a 2 zone case (Mainboard on one side; Disks on the other):
http://www.lian-li.com/en/dt_portfolio/pc-d600/
Till now I read so much about different types of fans (high airflow or high static pressure), but still I have no idea what to take for this specific case as intake and exhaust of the mainboard side.
Like you can see from the link above there is not much in the way because of the 2 sections (so normally I would say high airflow), but then, there are filters before the fans (so normally I would say high static pressure).
As GPU I will use 1 or 2 Sapphire HD7990:
http://www.sapphiretech.com/presenta...pid=1914&lid=1
Those cards seem to swirl a lot of air inside the case (spits air out in all directions including down at the motherboard) so I think they need a case with a good airflow.
If so, how do GPU-fans like these should infect the choice of the intake and exhaust fans?
So basically what I need are 3x 140mm fans for the front (mainboard side) and 1x 120mm fan for the rear (mainboard side).
What fans would you suggest? (Brand, Model, Type)
I would say the "Front: High Static Pressure, Exhaust: High Air Flow" would be the best solution, but I want to ask whats your opinion... ;)
So, why this is my opinion:
1) A lot of air needs to come into the case through the filters and I have place for 3 fans. (High Static Pressure)
2) Because the GPU seem to swirl a lot of air inside the case I want to have it out fast where I only have 1 fan. (High Air Flow)
But I have no idea if that makes sense? ;)
Greetings,
Cédric :)
More about : type case fan suggest case lian d600 gpu sapphire hd7990
