Approximate Purchase Date: The closer the better.
Budget Range: 1.5-2k$
System Usage : Games at max settings, streaming games at max settings, running multiple screens, bragging rights.
Parts Not Required: Depends on what's broken, hopefully: PSU, RAM (DDr3 Dominator 12gb), HDD's, Chassi.
Preferred Website(s) for Parts: Swedish ones
Country: Sweden
Parts Preferences: Intel, Gforce.
Overclocking: No.
SLI or Crossfire: Don't Think so.
Monitor Resolution:1680x1050 and a 42" tv.
Additional Comments: Yesterday I tipped a glass of water over and water got into the forward part of my system, a heartbreaking mistake to say the least, almost brought me to tears. I built the system myself in 2010 and it has worked flawless ever since..
The chassi I use is an older raven where the mobo is tilted 45 degrees to allow for hot air to escape directly through the roof (meaning it has a roof only protected by a plastic mesh cover). The part of the mobo which holds the PSU and so forth didn't get any water at all.
I'm pretty sure the ram, psu and hdd's are fine (didn't get any water on them) but since I'm not educated in the consequenses of water vs electronics, I don't know if parts will break even if only a connector in the "other end" got some water on it. I'm also pretty sure all the fans, my megahalem cooler and cd-rom escpated unscathed.
Optimally I would like to swap Mobo, CPU and GPU. GPU prices in Sweden: 450$ for a GTX770 and 500 for a GTX970. CPU-wise I glanced at the i7-4790 but maybe it's a little over the top for my requirements?
I wouldn't mind for my new mobo to have WIFI since it's remotely located in regards to the router.
Help is appreciated more than you can Imagine, it pains me so much to be without a system.
Best regards and with gratitude in advance,
OEW
Country: Sweden
Overclocking: No.
OEW
