The HDD Seagate Barracuda 7200.10 250GB ST3250410AS 3.AAC worked properly for years. Recently I saw that it did not start every time when desktop computer is powered on (sometimes it just won't start, after powercycle of the computer it started properly). This is not the primary HDD and I have it encrypted with some simple 3rd party software.
So it stayed encrypted for some time. Few days ago I tried to decrypt it and I ran into issues. First it did show I/O read errors, but - strangely, during writing, during the decryption process. Decryption process started, went to some point and stopped. Next time it did not go to the same point it stopped earlier. Next time even earlier, so I decided to make a raw copy of the entire disk. I saved the raw copy of complete 250GB HDD to image file (I cannot be sure if data inside this file is perfect, it was made by raw copy tool so it just skips bad sectors).
After I made it, I bought second Seagate drive (this time I bought 7200.12, I did not find (same as original) 7200.10 at local store), 250 GB HDD. So I put there the raw copy of the saved raw copy which I mentioned. Unfortunately it did not work. The decryption program just stopped.
I connected both older 7200.10 (to motherboard) and new 7200.12 (thru USB to SATA adapter) to one workstation, then I tried to make raw copy directly from the 7200.10 to 7200.12. I got number of CRC errors. Raw data copy program worked much slower, it shows CRC errors. So, copying speed is very slow, 5-10 times slower than usual, because of those CRC problems.
Anybody experienced similar issues with this HDD?
I must say - standard programs for HDD recovery are not perfect to be used for this issue because - the disc is encrypted (standard programs are usually trying to search for typical file types and to recover them).
Which steps may be considered now to resolve the problem? Any suggestions?
Thank you.
Thank you.
