Hi,
I am trying to set my resolution to 1360x768 which is also my monitor display, but when I do this, these strange black lines which then turn to white begin to show up and after 15 seconds go back to the previous display, the minimum resolution I can get is 1280x1024 and then the next one up is 1600x900, in between them wither show up with with and black lines or say out of range.
I've been trying to fix this for nearly 2 days and I do have some common knowledge with this so I am not a noob with PC's
Thanks alot,
Aidan1406
White and Black lines images:
imgur.com/YRZfZ5Y
imgur.com/vRgs0mT
imgur.com/XEJnebA
imgur.com/g1VZ7J4
Thanks alot,
Aidan1406
imgur.com/YRZfZ5Y
imgur.com/vRgs0mT
imgur.com/XEJnebA
imgur.com/g1VZ7J4
