Newly built PC problem with monitor signal not detected
Jamestyy
5
Hi All,
Currently I just have a newly built PC but monitor message show "No Signal Detected" with black screen.
Computer build up items:
ASUS Z97 Deluxe motherboard
ASUS Geforce GTX760 2gb
Kingston 2x8gb DDR3 Ram
Intel i7 4790 4Ghz
Display card connected to monitor using DVI cable .
Please Le me know if you could help.
Thank you.
Jamestyy
5
I have tried on my old graphic card and monitor, both still gave me message from monitor "no signal detected".
I suspect motherboard compatibility issue or defective?
Jamestyy
5
The only thing I haven't try is the inboard graphic card because the motherboard only have mini and normal display port.
May be I will try HDMI to my TV later.
Jamestyy
5
What I have tried connected with all new built items above:
- no beep sound detected
- motherboard is running because it got an switch to the board that I use to turn on and off. Asus z97-deluxe
- tried with old graphic card - still giving no signal detected from the monitor.
- is an old monitor benq xl2411 - still can run on my previous pc - DVI cable checked ok.
- new power supply Corsair RM650 with correct 6+2 pin connected with green leg light up on graphic card Asus Geforce Direct CU II 2GB
Will try later:
- inboard graphic with Mini DisplayPort to DVI to my monitor - need to get one later
- unplug everything except motherboard, graphic card, CPU to power supply later.
- unplug CPU and reinstall again
