I recently bought a TX3 off ebay, but they gave me a refund because they were out of stock, which game me some time to think.
I WILL be wanting to overclock my i7-4790k, for emulation purposes, and that fan might not be good enough to do so (Not sure)
So, considering my case is a Mid-Tower, with not much space, i'm not sure which liquid coolers will actually fit at the back where the radiator and fan is meant to fit.
Currently, there is a 120x120mm fan at the back of my pc, horizontally, it just fits, vertically, there is about 15mm clearance above, and 30 or so mm below (Affectively 15, because the radiator is gonna be symmetrical no matter what)
If a liquid cooler isn't a suitable addon for my small case, then what air cooler should i get for it?
From my motherboard, there is 160mm clearance (technically 140mm, due to a 20mm case fan above it, but that can be removed if need be)
The TX3 EVO was recommended to me on another thread, however, it was apparently a low profile cooler.
Or, if nothing suits my case for overclocking purposes, i guess i'll be forced to get a Full Tower ,or a bigger Mid Tower.
Case: Coodmax N81 (Mid-Tower)
CPU: I7-4790K
PSU: 750w
GFX: R9 270x, and soon a gtx 970.
CPU: I7-4790K
PSU: 750w
