Hello,
I recently purchased an ASUS DirectCU II R9270X, based on an attractive price and a number of reviews mentioned it had a decent amount of room for overclocking thanks to the cooler.
When I run Passmark Performance Test, at stock speeds I get a 3D Graphics Mark of 4,700, better than the average result on Passmark.com.
However, even when I overclock slightly, the score either goes down below 3,000 or I have a driver crash, and recovery.
The temps are not even going near 60c.
I cleaned drivers and started fresh, same issue.
I thought maybe it could be the PSU but the min PSU recommended is 600W and I have a 650W Silverstone Zeus ST65ZF. However, I also read that the minimum amperage of the +12v rail should be 24amps.
The 2 PCIe cables on my PSU are marked +12v3 and +12v4, which according to the specs are 16amps and 8amps, which = 24.
Could that be the reason it works fine at stock clocks but if I try to push it even a little I have issues?
I thought I had read somewhere that the maximum amperage is the total of all 4 +12 rails, is that true? if so then it should be 55amps right?
