need a feed back about Samsung S22D390H 21.5 Inch LED LCD Monitor
moking01
204
what do you guys think about this monitor ?
mainly i'll be changing my old monitor cos of screen tearing issues, would i get rid of such issues with this monitor ? and what is its max. refresh rate ?
my specs
intel core i5 4440
h81m-s2ph
sapphire r9 270x dual x
4x2gb kingstone hyperx
seasonic eco 500w
moking01
204
i've went through every single test that could be done on my pc components and it was not any of them, when i used softwares to enhance the v-sync seems like it fixed the issue...means that its a screen tearing issue.
michaelwebb
206
im the same pal bult my rig whats great well i think it is anyway novice at all this sorry but im using my Samsung 40inch in my room and it lights up the room to much when my girlfriend is going to sleep so i can buy that monitor tomorrow for £50 but not sure if its any good. this is my pc spec
cooler master haf x full tower case with 4 corsair 200mm blue led fans.
ASUS P8Z77-V motherboard with wi-fi adapter
Intel i5-3570K CPU unlocked version
16gb ddr3 1600 corsair ram
Cooler Master Nepton 140XL cpu cooler
ocz zx 1250 watt gold psu
1x sapphire hd 7970 3gb ghz graphic card
1x xfx r9 280x 3gb graphic card
SSD Kingston HyperX 120GB SATA3 3K 2.5-inch Gaming Solid State Drive
2x 1tb sata hdd for storage
Dvdrw drive
and this is that monitor
http://www.samsung.com/levant/consumer/computers-peripherals/monitors/led-monitor/LS22D390HS/ZN?cid=uk_affiliate__=1zzx8HSZN2c8VBF2CfUPhWcoUkVXZlVNkQQHx80
thanks for helping.
Latest posts
