Help And Info Regarding a Remote Start System, 02 Accord Coupe
AnarchistRise
19
Heya,
Its getting colder here in the morning, so a remote start system is looking more and more like a good idea as the days drag on. The only problem is I really have no clue what I am shopping for.
I have done a little bit of research, And will probably end up going to service shop somewhere to have it installed. I have a budget of around 400$ cnd (including shop time for the install) am looking for some advice on what Systems preform well at an affordable price point. Would hope to have a 2way system, But nothing overly fancy is need.
Vehical Specs,
2002 Honda Accord Coupe SE,
4cyl FW Drive engine
Stock Sound System/ Deck/ Car alarm
Auto Door locks /Alarm /Trunk on Keychain FOB
Anyone have a recommendation, advice, or general knowledge that I Should know before I start asking around locally? I am terrible at real life so the more knowledgeable I am the better. If you can, please include Systems, Model Numbers, personal experiences, and Adapters or wiring harnesses, any hidden costs I may not see in a local shop right off the bat.
It does have some silly anti theft thing where a code is required to start the electronics if the battery has been disconnected - Will this pose a problem?
Thanks,
Anarchistrise
$400 will get a 2 way system professionally installed in your vehicle (custom sounds or audio express)
If it's anything but Viper or Auto-page (brands), don't waste your money.
I have the C3-RS-730 2 way remote start and alarm from auto page installed in all of my vehicles.
I installed them myself, but this is by no means an option for someone who has never installed a remote start before.
I heavily recommend you do not even attempt it yourself, unless you have an experienced tech over your shoulder.
