Hi all,
I've got a GTX 770 and have been using it with a single monitor display for around a year and a half. The single monitor was connected via DVI from the card to HDMI in the monitor. All worked fine.
I've now upgraded to a dual monitor set up with two Acer 27" G Sync monitors. Both monitors come with a DP to DP cable but my GTX 770 only has one DP port. Therefore, I've bought this DP to DVI cable to hook up my second monitor.
So overall:
So overall:
I have my main display hooked via DP to DP
I have my secondary display hooked up via DVI to DP
Only having the DVI to DP cable connected on boot up/after boot up
Having both monitors connected before/after boot up
Connected both monitors individually using the DP to DP cable (to confirm both monitors work and they do)
