Please help me finish this build: http://pcpartpicker.com/p/dHfCt6
I want to have as small case as possible that can fit in the graphics cards and stay as cool as possible. I don't plan to overclock anything as long as it's not necessary, but the cooling system has to be adequate and keep the components on the cool side.
The case should preferably have at least 2 external 5.25" bays and 6 internal 3.5"/2.5" bays AFTER fitting in the GPUs and cooling systems. Also if there is leds and colorful stylings and such, then those should be preferably red/black or anything that fits the Asus ROG theme. Also carrying handles would be awesome.
I would like you to suggest a case (mid tower if possible) and a plan to keep the system cool in that case.
So any suggestions? Any help is appreciated.
