Just completed a pc build. My GPU has a 8pin and 6pin PCIE connections. However when i connect both PS PCIE 8 pin (6+2 pin) and single 6 pin connectors to the GPU, the monitor won't come one. The system seems to power on and all fans are spinning, but no signal from monitor.
If I remove one of those PCIE connectors whichever either the 8 pin or 6 pin or connect two 6 pin PCIE connectors (6pin pluuging into 8 pin socket) the monitor comes on and system boots up fine.
I'm unable to install the drivers for this GPU as the installation is just stucked at the detecting the device
https://www.dropbox.com/s/ueuy4p9elwuwggm/detecting.png?dl=0
What could be my problem?
As far as i know this GPU needs both 8 and 6 pins connected to work as designed
System build http://pcpartpicker.com/user/mrpaulrich/saved/p9vD4D
