C Crider6 Reputable Jan 9, 2015 1 0 4,510 Jan 9, 2015 #1 i bought a gigabyte radeon 7950 for my z77 extreme 3 and everytime i connect it to the gpu the monitor just says no signal, but if i take the gpu out and plug it in to the mobo it works, so what do i do?
ThatVietGuy Titan Nov 6, 2007 11,718 314 70,240 Jan 9, 2015 #2 PSU wattage along with make and model? You make sure to connect the two 6-pin connectors? Does it still output from the mobo if the GPU is installed? Upvote 0 Downvote
