D dvshck Reputable Jan 13, 2015 6 0 4,510 Jan 13, 2015 #1 I'm using a second monitor , the problem is when i want to change the resolution to a higher resolution its says its not possible though my video card max. VGA output is 2048x1536 but i cant even get it higher than 1280x720
plywrlw Admirable Jul 5, 2014 2,811 0 7,960 Jan 13, 2015 #2 You'll need to give us more information please. What're your monitors? What GPU are you using or are they plugged into your motherboard? Upvote 0 Downvote
D dvshck Reputable Jan 13, 2015 6 0 4,510 Jan 13, 2015 #3 plywrlw : You'll need to give us more information please. What're your monitors? What GPU are you using or are they plugged into your motherboard? im using a GeForce GTX 660 TI 2GB , both are plugged in on that videocard Upvote 0 Downvote
plywrlw Admirable Jul 5, 2014 2,811 0 7,960 Jan 13, 2015 #4 Thanks. Are you using DVI, VGA (D-Sub) or HDMI to connect both monitors? Upvote 0 Downvote
