R Roy Schultz Reputable Jan 20, 2015 2 0 4,510 Jan 20, 2015 #1 looking for a solution to my audio problem
Solution B B boosted1g Jan 20, 2015 If monitor has built in speakers (that takes HDMI input): Go to audio control panel and select hdmi as output device If monitor does not have built in speakers: You will need an external set of PC speakers
madmatt30 Titan Ambassador Jan 1, 2013 24,574 650 91,240 Jan 20, 2015 #2 Does the monitor have built in speakers?? Or using a separate speaker set?? What motherboard ?? Are you using a seperate graphics card or onboard video? Upvote 0 Downvote
B boosted1g Titan Jun 12, 2013 14,846 8 74,965 Jan 20, 2015 Solution #3 If monitor has built in speakers (that takes HDMI input): Go to audio control panel and select hdmi as output device If monitor does not have built in speakers: You will need an external set of PC speakers Upvote 0 Downvote Solution
McDuncun Honorable May 6, 2013 987 1 11,365 Jan 27, 2015 #4 If your using a discrete graphics card the options for the HDMI sound output should be there. In my experience it`s disabled by default... Upvote 0 Downvote
