All the fans and the LED turns on. I built it a few weeks ago and it worked until yesterday when it shut itself down and possibly overheated.
Windows home 7 premium 64bit
ASRock 980DE3/U3S3 motherboard
corsair cx500m power supply
AMD FX-6300 CPU
cooler master hyper evo cpu cooler
corsair force series 60gb SSD
WD 1TB blue internal HDD
MSI R9 270 graphics card
kingston 8GB RAM (2x4) 1333MHz DDR3
Bitfenix Comrade case (which is actually too small for the cpu cooler)
and a disk drive and monitor from the previous computer
I have reseated everything except the CPU (the cooler is annoying to remove and put back on)
I also tried connecting the computer to the TV (its the only other screen i could use) by a HDMI cable to see if it was the monitor that wasn't working but it didn't work on the TV (although I'm not sure its supposed to). Also when i disconnect the cable from the computer to the monitor it says there's no VGA cable but when it is connected it goes into power save mode.
I'm starting to think that either the graphics card or the CPU is damaged. If anyone has any other ideas or suggestions on what to do I would appreciate it.
AMD FX-6300 CPU
