So I'm looking at this build on NewEgg for about $1200. Is there anything that stands out where any of you helpful forum folks think I may run into trouble, compatibility issues, ect. ? Am I missing anything? This motherboard fits in this case, that heat synch works with the i7-4790K, the motherboard and GPU aren't going to bottleneck, and so forth?
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
NZXT Source 210 Elite White Steel with painted interior ATX Mid Tower Computer Case w/ Black Front Trim
Western Digital WD VelociRaptor WD5000HHTZ 500GB 10000 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
Western Digital Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
EVGA 02G-P4-3753-KR G-SYNC Support GeForce GTX 750 Ti Superclocked 2GB 128-Bit GDDR5 PCI Express 3.0 Video Card
Rosewill Glacier Series, Glacier 700M, 700W 80 PLUS BRONZE Certified, Modular Design, Single +12V Rail, SLI & Crossfire Ready Power Supply with Silent Aero-diversion fan
HyperX Fury White Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model HX316C10FWK2/8
Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor BX80646I74790K
Microsoft Windows 7 Home Premium SP1 64-bit
Phanteks PH-TC14PE_BL 140mm UFB (Updraft Floating Balance) CPU Cooler
EVERCOOL HD-F117 Aluminum HDD Cooling Device
Thanks,
-=LCS=- teh_fake_BANE
Thanks,
