I recently built secondary computer, and by the time i had finished building it, i only had about $10 or so before i exceeded my $500 budget. So i decided to go to Goodwill and bought a cheap FPD1520 gateway monitor. i hooked it up and was surprised to see the screen resolution was only 1024x768. I installed Smite and opened the launcher. But the play button is at the bottom of the screen, and about 3 fourths of the launcher gets cut off because of the low resolution. I move the launcher's window around, but anything that could not originally fit into the screen was cut off. A similar thing happened with Planetside 2. Does anyone know what i can do to fix this?
