To start, here is the complete part list I ended up with in my custom build that I just finished over the past weekend:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-Z97X-UD5H-BK ATX LGA1150 Motherboard
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer
Monitor: Asus VG248QE 144Hz 24.0" Monitor
My issue is with the monitor. I used an old monitor via VGA input to do the initial setup of the BIOS and OS install without issue. When my new monitor (the Asus VG248QE) arrived via UPS yesterday, I unboxed it and set it up with my machine. Initially, I plugged the DVI cable from the monitor into the on-board DVI input on my GIGABYTE motherboard. However, when I started up the machine, I received the statement on the Asus monitor saying "DVI: No Input", and then the screen went into power saving mode. I turned off the monitor, unplugged it from the monitor source for a good minute or two, plugged it back in, and tried again. Same error. I went ahead and attempted the process with an HDMI cable instead, and had the same error show up "HDMI: No Signal." This, again, was into the on-board HDMI input on my GIGABYTE motherboard.
At this point, I was a little frustrated, so I tried to plug the Asus monitor in to my working laptop via HDMI, and it worked just fine. Came up without a problem, and displayed everything. Not sure what's going on...
A note: I have not yet installed the drivers to my graphics card as I was hoping to do that with the new monitor plugged in to the motherboard, and just be able to switch it over to the graphics card input once the appropriate drivers were installed. In addition, I have not yet installed the drivers for the monitor because the monitor needs to be plugged in to the machine for the driver installer to recognize the product, and I haven't been able to get the monitor to display anything at all in order to go through that process. It's a whole running around in circles kind of experience!
I am not at home for the next few hours to be able to troubleshoot/tell you anything further about the machine and monitor. But I was hoping that I could get a few ideas from you all here that I might be able to try once I get back to my machine and see if any of your advice helps. If it doesn't at that point, I'll update this post and see if there is anything further that could be attempted before I chuck the monitor out the window!
Thanks for any and all help in advance.
