I'm trying to make a test eyefinity setup using 2 older lcd monitors 1680x1080 and combine it with my newer 1920x1080.
The problem is that the older ones have only VGA and DVI-I, but the GPU Asus 280x TOP have only 2x DVI, so for the third monitor can i use the motherboard VGA port and will GPU be able to use it for eyefinity? The motherboard doesn't have onboard graphics i think, it's Asus h97m-e, the CPU is i7 4790.
