I know these questions have been asked in the past so please forgive me but I can't seem to find the exact solution for my particular setup.
First I will list the equipment. Please let me know if anyone needs more information on that.
Three Monitors - 2-ViewSonic 27" Monitors (VX2753MH) & 1-LG 34" UltraWide (34UM65-P)
Computer is Dell Precision T5500 Running Windows 7 Professional
Graphics Card - AMD FirePro V 5900 (2-DisplayPorts & 1-DVI Port)
Ok so my first problem is getting all three displays to run at the same time. Only two will run at once. I am using two Insignia DisplayPort to HDMI adapters and one RocketFish DVI to HDMI adapter. HDMI cables are then routed to each of the three monitors. Ive tried all the normal troubleshooting and no luck.
My second problem is the 2560x1080 resolution that I can not seem to get on the LG monitor. 1920x1080 is the highest it will go so I either have everything stretched, or I have huge black bars on both sides.
The LG monitor does have a DisplayPort inlet on the back so I was thinking of getting that, but the DP to HDMI or the DVI to HDMI should do the same thing right? I dont know. At this point I feel like im just going in circles. Any help at all will be much appreciated. Thanks
