So I'm wanting to buy a new PC but I'm not entirely sure what I need. I want to run dual monitors with a games such as Skyrim, CS:GO, Dark Souls, Evolve etc. at high/medium kind of settings. Simultaneously (On the other monitor) I would like to be able run programs such Fraps or Dxtory, OBS, Audacity, Skype and an internet browser all at once without much or any performance drops. (This is mostly because of recording and streaming purposes) Along with that I want the PC to remain fairly quite.
These are the parts I have selected so far. I need help checking there all compatible and balanced. If they aren't balanced I would prefer to downgrade rather than upgrade unless it would significantly drop the performance and restrict me from having the setup I list above. Also will all the parts fit in the case or will I need to select a new one?
Specs:
CPU: Intel Core i5-4690K Unlocked Quad-Core, 3.50GHz (3.9GHz Turbo), 6MB Cache, LGA1150
Motherboard: Gigabyte Z97MX-Gaming 5 4x1600MHZ PCI-E 3.0 Bigfoot USB3.0 HDMI/DVI-D/VGA mATX
RAM: Corsair Vengeance Pro Series - 16GB (2 x 8GB) DDR3 1866MHz C9 (CMY16GX3M2A1866C9B) - Blue
Storage Device: Seagate 3TB Barracuda 3.5" Internal Hard Drive ST3000DM001
Power Supply: eVGA SuperNOVA 750W B2 80+ Bronze Power Supply
Optical Drive: Lite-On Super AllWrite SATA DVD Re-Writer OEM (24x - Black)
CPU Cooler: Corsair H55 Quiet CPU Cooler
Graphics Card: Gigabyte GeForce GT 740 4GB GDDR5 Graphics Card
Windows: Microsoft Windows 8.1 64 Bit OEM - ENG INTL (WN7-00614)
Case: CoolerMaster Silencio 452 With USB3.0 Mid Tower
Also last thing, to my understanding I will have at a D-Sub, DVI-D, HDMI, at least 6 usb ports,a RJ-45 port and audio ports (And some other things that I don't really need) accessible from the surface, yes? Thank you to anyone that helps.
Specs:
