Hi there,
So i have been having this problem for a couple of months now, and after searching everywhere on this website and other forums I have not found a working solution to this problem.
These are my PC Specs:
OS: Windows 7 Professional 64-bit SP1
CPU: Intel Core2Duo E7400 2.8 GHz Not Overclocked
Motherboard: Asus P54G41T-M LX
RAM: Transcend 4.00GB Dual-Channel DDR3 @ 534MHz (7-7-7-20)
GPU: Point Of View Nvidia GTS 450 1GB Edition
Hard Disk: 500GB Seagate ST3500418AS
The problem I'm having is that whenever I play games (for e.g,GTA IV,NFS Most Wanted 2012,Team Fortress 2,etc.), The sound from the game freezes and then my monitor changes to black and then just shows "Power Saving Mode" and then doesnt switch back on, until i reset my PC directly. I have tried so many solutions( like checking for malware, reinstalling the OS, decreasing game's graphic settings or changing the GPU power cables.) Also whenever I restart my PC (I usually keep it on), in the first 15-20 tries, my Display just shows " power saving mode" even though I can hear Windows boot up.
The reason I think the GPU is having problems is because even when my GPU's core temp. reaches 80C the gpu fan does not kick in, and when i manually turn on the fan using MSI Afterburner, the display driver crashes and my monitor goes to power saving mode and then switches back on, with a notification in the system tray saying "The Display Driver stopped responding and has been recovered". Also when i connect the VGA cable to my motherboard directly( it is normally connected to the GPU itself ) The crashes dont happen anymore(Since Graphic intensive games dont work without GPU, I played Team Fortress 2). Any more info that is required, I will try to provide.
Any help is appreciated.
P.S: I'm 17 and still in school, so buying a new GPU right now is not a viable option.
P.P.S: I live in India, where room temps reach 48C in summers, so having a resting(no load) temp of 50C is quite good.
