Hello! My desktop has been doing this odd thing for the past year or so. My processors max speed is 3.31 (4.2 Turbo) but it always runs at 3.58 and I have no idea why. nothing I do will lower the speed, well it does but only to 3.54 and only for a second. The speed is the same at idle and under load, I mean ALL the time. I do have AMD Overdrive installed, however I do not use it as it tends to crash my computer when applying any changes, so all its settings and changes have been reverted to default, and it doesnt get started ever. The process isnt running so I dont think its that. My temperatures are fairly low which is good. At the moment it isnt a problem, unless you guys believe it is. I have a few questions regarding this;
1) Why is it doing this?
2) Will it damage the processor having it run at these speeds constantly?
3) If there is a need to stop it, how would I go about doing that?
Please let me know if you need any more info, I will gladly give it!
And sorry for the long post, but I like to be descriptive lol.
Thank you!
Specs:
Processor: AMD FX-8300
GPU: NVIDIA GTX 650 1GB
OS: Windows 8
RAM: 8GB
Motherboard Manufacturer: ASUS (No idea what model)
Thank you!
Specs:
OS: Windows 8
RAM: 8GB
