Dual monitor issue - no signal the one with HDMI
TheGhost84
Hi,
I want to work with two monitors at the same time, extended display. My video card is a PNY GeForce GT 730 with three outputs: VGA, HDMI and DVI-D.
I want VGA to VGA for Monitor A and HDMI to HDMI for Monitor B.
They both work perfectly when plugged in separately but when they are plugged at the same time, only the Monitor B (the one with HDMI to HDMI) lost signal and is not detected.
What can I do so both monitors can work together?
With Monitor B I tried with the normal HDMI cable and also with an HDMI to VGA adapter. In both cases the result is the same.
TheGhost84
Hi, thanks for answer.
No, just one, the Monitor A (VGA - VGA).
The Monitor B (HDMI - HDMI) is detected only if it is connected alone, but in the moment I connect the Monitor A, the Monitor B lost the signal and not detected.
