No, that port on the speaker needs to be connected to the same type port on the monitor, if it has one, and the main input for the Z323 needs to be plugged into the green speaker output on your sound card or motherboard. If you have something plugged into the green speaker output on your PC you probably don't need to disable anything in sound, it should switch automatically.
