mobo: gigabyte ga-h97-d3h, which has 3 sys_fan outlets (1, 2, and 3), all of which are 4 pin
case: nzxt source 210 elite
1. I mistakenly bought several 3 pin fans, with no adapters. I would like to
connect them together, and simultaneously convert the connection to 4 pin. This way they can all (in effect) connect to sys_fan 1. What type of adapter(s) are needed (specific urls would be great)?
2. For ease of maintenance, I want to put one of the 3 pin fans on the left side panel and connect it (by itself) to sys_fan 2, with sys_fan 3 held in reserve. What type of adapter merely converts the 3 pin to 4 pin?
Note: Since I'm going to run them all at "full", I don't care about the loss of
functionality converting 3 pin to 4 pin, re the Bios specifying "partial" speed.
3. I will use 8 fans: 2 each on the front, top, and bottom, and 1 each on the left and back. Unfortunately, the case's front bezel (panel) has no venting for the front side fans; there is about a 1/2 inch airway between the front fans and the front bezel. All other airways are fine.
Two of the fans, the back and one of the top, are pre-wired-configured; these two can not be easily altered. The case's documentation provides a configuration diagram which suggests having air come in the front and the bottom, and go out the left, back, and top.
Given that the back and top are forced, and that the front will have a limited airway, what about using the diagram's suggestion, _except_ having air come in the left side, rather than go out? In other words, does the blocked front panel "balance" changing the #fans-in/#fans-out from 4/4 to 5/3?
4. Naive, but I can't resist... What about abandoning the "directed air currents" approach and configuring all 8 fans to send the air out. Would this create an internal "low pressure area", deter the internal (hot) air from escaping, and thus cause the fans to be "working against each other"?
Thanks very much for any help.
