Hello
I search all my times how to setup dual monitor, in my GPU there is DVI,HDMI,VGA Ports, i plug monitor 1 plugged with VGA on GPU and second monitor i wanted to use VGA to HDMI cable but when i plug it nothing happen just "Check Signal cable", same thing on DVI. i try to plug on motherboard with VGA and it going well so far. but i want to use 2 monitor in 1 GPU. and my monitor only supports VGA port only.
Spec:
Win 7 x64
GPU: AMD Radeon R7 240
Ram: 8gb
Motherboard Gigabyte H81M-S2PH
any suggestion?
Spec:
Win 7 x64
Ram: 8gb
any suggestion?
