hello all which do you think is better for DD, DTS AND THX for surround sound Logitech z906. i want to use DD for Battlefield 3 but the receiver does not pick it up at all. only in movies i can get DD, DTS and thx. i tried different settings battlefield 3 audio but nothing works. yes i have the stereo enhancement off. im using spdif (toslink)
so tell me why the one you select better? dont say just because its blah or because its a external. i want to know why what is your opnion have you use them both before how did you use them, what cables you used.
