T Tibo Marasigan Distinguished May 30, 2015 71 0 18,630 Jun 9, 2015 #1 i just check my psu and its 600watts and i just see something that it right 56-60hz does this will affects my 120hz monitor?
Solution I I i7Baby Jun 9, 2015 No. Even your monitor runs on household electricity that is 50-60Hz depending on where you are. It still doesn't affect your monitor refresh rate.
I i7Baby Titan BANNED Jul 25, 2012 44,084 2 106,960 Jun 9, 2015 Solution #2 No. Even your monitor runs on household electricity that is 50-60Hz depending on where you are. It still doesn't affect your monitor refresh rate. Upvote 0 Downvote Solution
T Tibo Marasigan Distinguished May 30, 2015 71 0 18,630 Jun 9, 2015 #3 in AMD CCC i have maximum detected refreshrate of 75Hz but in screen resolution its only 60hz so what will happen if i get the maximum Upvote 0 Downvote
T Tibo Marasigan Distinguished May 30, 2015 71 0 18,630 Jun 10, 2015 #5 what u think is better i max it or stay at 60hz? Upvote 0 Downvote
T Tibo Marasigan Distinguished May 30, 2015 71 0 18,630 Jun 10, 2015 #6 So when i set my monitor to 75hz it comes blurry Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,084 2 106,960 Jun 10, 2015 #7 Then yes - you should stay at 60Hz. Upvote 0 Downvote
T Tibo Marasigan Distinguished May 30, 2015 71 0 18,630 Jun 10, 2015 #8 Btw sir how do i get 60fps stable in dota 2 i have psu:600watts videocard: r7 240 2gb ddr3 monitor:LCD819 RAM:3gb Processor: Intel E5500 dualcore @ 2.8ghz motherboard: GA-945GCM-S2L Upvote 0 Downvote
T Tibo Marasigan Distinguished May 30, 2015 71 0 18,630 Jun 10, 2015 #9 I dont want to change my Videocard because in benchmark in dota 2 it says 55min 60avg 71max Upvote 0 Downvote
