The build I'll be using - http://pcpartpicker.com/p/cQLFxr
I plan on buying a new monitor for the build above, but am unsure whether to go for a 24 inch or 27 inch... The monitor I plan on buying - http://www.amazon.com/AOC-G2460PQU-Ultimate-Performance-Professional/dp/B00HY7PAUC/ref=sr_1_1?ie=UTF8&qid=1435893860&sr=8-1&keywords=aoc+144hz
Keep in mind that I plan on playing all of the latest games on maximum settings 60-90+ FPS. I'll also be playing with graphically heavy mods on games such as: Skyrim, Minecraft, and GTA 4/5.
I figure if I go for the 24 inch, I'll have an easier time running the games listed above. Is this true, or should I go for the 27? I'm really new to this type of stuff, so go easy on me.
As usual, any advice is taken into consideration.
