I just got a new monitor, that is capable to use 2560x1440 @ 144 Hz but I can only use that resolution at 60 Hz. I have tried the DVI-D cable that came with the monitor and a mini DP- DP cable that I puchased separatly. I have tried several drivers and beta drivers for my AMD Radeon HD 6970 card. The card has Displayport 1.2 and should support 1440p @144 Hz.
Get the message Displayport "lower settings applied" on windows 7 startup. I can set it to 144 Hz in Amd control senter but then the max resolution is 1080p.. Can anyone help me please ?
Olebrom
Norway.
Olebrom
Norway.
