I'm putting together a decent pc I can use for everyday use and casual gaming. Please check out the parts I have put together below, and tell me what I can do to make it better without increasing the price. Also, more importantly, point out anything that will not work! I plan on using my current HDD /w windows vista, and my current dvd/cd rom drive until I can afford to buy a large ssd and a new OS.
Thank you. I know it takes a lot of time to go through this and make sure everything's compatible, and I really really appreciate it, because I only want to buy this once.
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811553018
Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131942
Gpu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127788
Psu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152061
Ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231740
Cpu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113326
Wireless Adapter:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166060
Extra case fan and molex splitter:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835264003
http://www.newegg.com/Product/Product.aspx?Item=N82E16812198025
Case:
Mobo:
Gpu:
Psu:
Ram:
Cpu:
Wireless Adapter:
