Hi men (and women, maybe)
I just purchased a small 19 inch 720p monitor just as a small extra screen for using when playing games. I am attempting to set up dual screens but ran into a problem. It will only use one monitor at a time. e.g, when I plug the small monitor into VGA on the motherboard, it will only work if the graphics card is physically not powered on. If the Video card (attached with DVI), is powered on, then the computer will attempt to only send signal from the video card, not picking up the VGA signal.
I'm asking if you guys know how to force it to pick up both at the same time!!
Specs:
Mobo - Gigabyte GA-B75MD3H
GPU - Gigabyte Radeon HD7850 2GB OC
CPU - Intel i5 3330
Cheers,
Jamie
Specs:
CPU - Intel i5 3330
Cheers,
Jamie
