I've just built my own PC and I used the VGA port to connect the monitor. I turned on the system and on the monitor it says: Checking signal... then it says D-SUB No Signal but I am using VGA. The CPU fan is spinning. There is a 4-pin connector on the mobo that says ATX 12V Power Connector but I don't have a cable from my PSU for that. I only have 1 RAM stick installed and the mobo only has 2 ram slots. The CPU fan is plugged into the connector. My PSU has a lot of cables that I am not using. It took me a lot of tries to put the CPU in (It's and AMD APU,No video card) and I think I might have bent/broke a pin. The front case fan did not turn on but I suspect it might be temperature sensitive. My power supply is an EVGA 400W which is overkill b/c the build is only using 85-100 watts. I have a hard drive and an optical drive installed. My motherboard is an ASRock FM268M-DG3. The monitor is a LG 24M56. I am using the stock heatsink fan. I don't have a mouse or keyboard plugged in. I used a screwdriver on the 2 little pins with the mobo in the case with everything plugged in and it turned on. I have just tried to reset the CMOS and I will edit with results. I removed the RAM and I got no beep at all. I switched the ram in the 2 slots and still did not work. I have never gotten a beep or anything from the computer. EDIT: Just tried to reset the CMOS, but it still says D-SUB no signal.
