Depends on the other hardware and your expectations.
Usually cheap water can be matched performance wise by a mid range air cooler like a hyper 212 (or so close it don't matter), then their the risk of water leaks that kills parts along with if the pump goes out your PC is 100% down till replaced where as a air cooler you could move a case fan to the CPU cooler if needed and keep rolling.
