I have an AMD FX-8350 with a corsair h80i gt AIO water cooler and I thought my temperatures would be lower than what they are. On Corsair link it says that ASUSTeK Motherboard CPU Temp is in between 38 and 40 at idle but there is another spot that says my AMD fx 8350 15.5 c but on CPUID Hardware Monitor pro 36-40. don't know which temp my cpu is actually running at? I have an asus m5a99x Mobo. If i didn't put enough Arctic Silver 5 thermal paste on, in between the CPU and the pump can it run a little hot? At load using 3dmark benchmark it got up to like 60 is that good or bad? And everything was set to performance mode on corsair link. 2 stock fans one pushing one pulling.
