Hi, I've got some problems with my computer. I have the classic "press the power button, computer fan spins, then stops, then spins... and so on" problem.
This is not a new build (over 3,5 years old). I have tried the trouble shooting sticky on these forums. I also did the paperclip test on my PSU, and it works as it should.
After detaching and then reattaching all powercables it worked again.
Yesterday, same problem. But after I disconnected the power cable from the motherboard (and the four pin connector), then reattached them, it worked again. So, faulty wires? Loose cables? Messed up hardware? It's troublesome if this keeps happening.
OS: Windows 7 Ultimate
Specs:
Processor: Intel Core i5 2500k
Video: Gainward GTX 970
Motherboard: Gigabyte GA-Z68AP-D3
Memory: Kingston HyperX 1600MHz 8GB
Hard Drive: Seagate Barracuda® 7200.12 1TB
SSD: 64GB Crucial m4
Cooler: Arctic Cooling Freezer 13 Pro
Optical Drive: Samsung SH-S222AB
Power Supply: OCZ ModXStream 700W
Thanks in advance for all help and tips!
Specs:
