I'm looking into setting up dual monitors through my graphics card. I have one monitor plugged in through a DVI-I port. I only have one DVI-D port and one HDMI port remaining on the graphics card, and I found out that if I want to hook a monitor up to the DVI-D port, I need an analog/digital adapter, which cost around 30 bucks. I'm cheap, so I want to see if I can use the HDMI port instead.
I found out that the monitor I'm trying to connect has an HDMI port on it. I figured I could theoretically connect the HDMI on the monitor to the HDMI on the graphics card. No signal conversion required, and the cable will cost less than 10 bucks. Could this be done? Or will I have to stick to buying a VGA/DVI-D adapter?
