for the last 2 weeks now i would start playing a game and it runs perfectly fine, no problems, pc still cool nothing over 50C for cpu/gpu/mobo or anything of the sort. What happens now is that when i quit the game. Try to either load up another game, or even watch a show or movie i downloaded (using mpc-hc) the computer will completely shut off randomly, no lag or blue screen just complete loss of power. I have to unplug the psu and reset the switch on it to be able to turn it back on. This happened at one point while loading up diablo 3, to when i tried to play the game again i had to run a repair on it because some files got corrupted. I thought at first it was a psu problem since it was always running extremely hot, but after some cooling adjustments, its now running nice and cool even under load. I also thought it may have been the outlet i was using, but after 2 different surge protectors and outlets the problem still occurs. If it lies in a new psu/motherboard then thats fine, only concern is not being able to afford it at the moment, and i need this computer for work related business as well.
System
AMD FX 8320 stock clocks - cooling with hyper 212 evo push/pull config
amd hd 7870 stock clocks
8GB corsair vengeance ram (stock)
psu - xtremegear 800W
Gigabyte GA-970-D3
ive swapped out the cpu/gpu from the originals well over a year and a half ago
both the motherboard and psu ive been using well over 4 years now. *IF* those are my problems then ill get new ones, but i cant for the time being due to financial constraints.
System
Gigabyte GA-970-D3
