I'm going to buy the LG 24MP77 monitor which is a 24" Full HD IPS monitor. It has 2 inputs: HDMI and VGA. And LG only bundles the VGA cable in the box.
Can I use the bundled cable and get away with it or should I invest in a HDMI cable? I know VGA is analogue signal but not sure if the quality will be bad enough to go for the HDMI route. If it'll be the same, then I'll stick with the VGA.
More Info: I'll use the monitor for gaming mostly and also light browsing. My current monitor is a decade old Viewsonic 17" 900p monitor that's slowly dying with too much backlight bleeding. Also my current Graphics card is a GTX 660 with a DVI to VGA converter.
